super lcd screen
rlp900
Quick question from someone who doesn't know much about the different screen tech.
I currently have one of the original DInc with an amoled screen and love it.
I know the rezound screen is hd, but is super lcd going to be a step down or will it still have as nice an image?
Thanks in advance.
Thanks in advance.
SLCD should be sharper/crisper than Super Amoled (which uses pentile matrix). However, at the higher resolutions and pixel densities of these new phones, I really don't know if you'll be able to see the difference. But you will definitely notice the more vivid colors on the Super Amoled versus SLCD.
While I prefer Super Amoled, I think SLCD looks just fine. Check out the screen on the Inc2. That is SLCD. Now imagine that it's 4.3 inches and has the pixel density of the iPhone 4. That's what the Rezound's screen will likely look like.
How will the Rezound compare to the dInc, in sunlight?
currently unless i have my brightness maxed out, the phone is almost useless in direct light. As a lot of you know.
