Help Super Noob 2.1 Help
j_bizz89
Hey i tried updating to the new De03/Root/Recovery/Custom Patch from SDX the day it came out and after hours and hours gave up because my windows vista wouldnt even start the update. Period. Then today I decided to give it another try. And to much my surprise I made it...Well Almost.
Right now my update is frozen at 87% with a 92 second elapsed time for about the past half hour. Im froze at the first part of the update to De03. I did everything STEP BY STEP from the SDX site.
Does anyone have any help they can give or please direct me in a past thread that described this issue?
ANY help would be amazing right now. Thank you so much.
use that link to download the 2.1 update file only first put in into the binary file and run the updater you might have a problem doing all 3 in one update.
ok ill check it out right now....
my fones still froze in this 87% updated mode
should i just unplug it or will that brick my fone?
Sounds like you might have a defective Download from SDX. I'd recommend redownloading the upddate .tar file and start over from the beginning.
yeah i just did all the root/recovery/and sdx custom update... im super stoked gonna b spending the next few hours customizing my fone now lol. i know you guys know wat it feels like. thanx guys. much love. out.
HAH!! It's never over--then there's joey's new Kernal w/ Numus's battery thingy etc.etc.
