I am rooted with "Super Root User" package.
Also used "One Click Lag Fix"
Because the issue I'm having with OTA update I'm thinking about using Odin 3 to put my captivate back to stock and may be root the phone using "One Click Lag Fix" and enable side loading.
My question is the " Super Root User" package came with 1.2 OC. Anyone knows or tried performance difference between 1.2 OC and Lag Fix.
Or any tip ?
Thank you
Or any tip ?
Thank you
