I spend few hours to investigate the mmcblk0p4. Using Android Commander, I was able to copy mod file to /dev/block. I restarted computer and start the AC. Went to /dev/block and the mod file was there. ON phone - I use Root browser and check the /dev/block - the mod file was there. I use Total Commander and the file was there. Reboot the phone and file was gone. The /dev/block is virtual folder/partition. Trying to get supercid by change the string will not work.
The question that I have - why do we need to change carrier ID to have s=off and why someone would point us to file that can not be change(virtual).
Any change to mmcblk0p4 will be lost upon reboot.
