Supernexus Jelly Bean Rom for SGS2 by Faryaarb
Build 3 being released on Saturday.. Can't wait for that
Plus the creator of the Rom Faryaarb is 16 today.... 16 years old that's incredible work by anyone's standards
My, how times change!
At 16 years old I was getting, extracurricular, practical biology lessons from my classmate, Jayne. ;)
Who said education isn't important?
All though in this case I think they were wrong when they said the pen is mightier than the sword!! :thumbup:
Hi, I have been running this on my s3 for about 3 days and it's been very solid.
Thanks to Faryaarb for a magnificent piece of work!!
I am wondering how to remove the persistent search bar on the home page. I figured there would be a setting to do so, but there doesn't appear to be.
I don't want to disable search, I just want a clean home screen and the ability to put the search widget where ever I want to.
With Voice features like Google Now, I don't really need the search bar at all.
Any suggestions?
Thanks,
SWH
I could not find away mate apart from chaning the launcher im afraid....maybe that has been changed in his upcoming Build 3 ?
How did you get Siyah Kernel 4.1.5 on this rom? I tried flashing siyah .1.5 on this rom and it won't boot... I had to re-flash the rom... How did u install siyah? By the way Build 4 of this rom rocks..been running it for 4 days now... please reply..
Sorry mate I no longer use this Rom I'm back on Neat Rom LPY...
What I do know is that a build 5 should be out in the next couple of days so might go back and have a look, I remember being very impressed with this Rom whilst running it
If it is based on cm10, which I think it is.... Since the 2.10.12 build, siyah isn't compatible..... It might be with changes but I'm still far too much of a noob to know what changes! Lol
Just so you know Build 5 was released a couple of days ago. I haven't tested it yet but I thought I'd inform you
Cheers
Just to resuscitate this thread on SuperNexus.
After being a couple of months on NeatROM Lite 4.6.1 XWLSN and kernel Siyah v6 beta 4 I decided to give SuperNexus ROM a try. I am really impressed!
My average battery life on NeatROM Lite was 30 hours, with all ironass STweaks settings. I thought that this is difficult to improve, but I was wrong.
Now, after 24 hours my battery is at 60% with SuperNexus v2.0 M1 (JellyBean 4.2.2). And I did not tweak any setting, i.e. the CPU highest frequency is 1200. And everything works as smooth as one can imagine.
So, I definitely suggest those interested to give it a try.
