Root Supernova rom
SJLS101
Hi,
Finally went for it and rooted my phone over the and am running the Starburst rom just now, but am thinking of changing to Supernova to move up to 2.3.
Has anyone used it or are running it now, and is the move worth it?
2.3 is better than 2.2 so that should be reason enough. We all know Droidzone round here. I haven't used it but he is a good dev so I would definitely go up a version.
Thanks for the advice, will have a look tonight I think.
Went for Starburst as found a few posts saying it was good. Also liked the way I could partition my SD card and convince the phone it was actually internal storage.
Any others you would advice?
