When trying to root my G2x, SOC gets stuck on "running psneuter" and freezes, having to be terminated via task manager. I don't understand what I'm doing wrong. I checked USB debugging, I ran as admin, etc, etc. Any suggestions?
If I remember correctly with SuperOnceClick psneuter only worked on 2.2. If you have a second try to use GingerBreak.
Open up SOC in admin mode and on the right side is a drop down window that says Exploit above it. You should be able to choose between psneuter and Gingerbreak. Try running Gingerbreak.
