Root SuperSu CWM zip for prevail
Necrotoxin
Those of you who may be interested in using SuperSu over superuser but don't want to install your SU app in data (can be deleted with factory reset) may have looked into using the CWM zip to install it as a system app, or maybe not. Either way, I would personally never trust installing my SU app as a /data app and it seems the SuperSU CWM zip from the original author doesn't work with our little prevails.
Even though that may be the case, I am here to offer you a solution! All credits for this go to bloodawn for his APKinstaller.zip and Chainfire (original Thread) for creating the app.
Basically I've taken the current cwm release and popped those files into bloodawn's APKinstaller and all is well.
Download link:
SuperSU-0.94-Prevail.zip
MAKE A BACKUP FIRST! You should always do this before flashing anything ever all the time!
Installation instructions:
1 Download the zip if you haven't already (derp)
2 Reboot into CWM
3 install zip from sd-card (come on you guys should know how to do this by now)
4 Reboot phone
5 Use titanium backup or some bloat remover to remove superuser
6 Reboot into CWM and Clear Dalvik (not sure if this is actually needed but it doesn't hurt)
7 Reboot phone
8 You're done
To reinstall superuser:
Download current ARM zip from Superuser
Follow the above steps 2-9 but instead of removing superuser in step 5 remove supersu
thx i always use link2sd just cuz it can see superuser and supersu so i can integrate into system then delete superuser but this lot quicker
