Root Superuser icon, but not rooted
Hi guys, i rooted my phone via the one click method and while i have the super user icon, i dont have any privileges. How can i just get the icon to go away since its not rooted
Are you really sure your not rooted? Download the newest busybox and see if you are then able to use root appear....and go into superiser and see if any apparently are listed
Yes, I had similar problem. Download titanium backup. run it. It will probably say root: failed. click "Problems?" at bottom, "yes" to download known working superuser.
Should be good to go.
well that will install a working busybox...superuser is fine as is
LOL, sorry. Correct, download working busybox. Guess I was so stressed last night thinking I screwed something up I wasn't thinking clearly about actual wording.
Basically, If you click "problems?", it's the only option of what to do.
