Root Superuser with ZV4 ROM needs update
Phil42
Member
I've successfully downgraded my phone to ZV3, towelrooted, installed CWM recovery, flashed
donjuro's ZV4 ROM, flashed boot and kernel (whew) so I believe I'm successfully rooted and on ZV4.
But (you knew there was a but) the Superuser which came with the ZV4 ROM says that the binary must be updated. It asks to chose an installation method and the only choices are "Cancel" and "Recovery Install". Recovery install give an "untrusted zip" warning. Even if I ignore the warning it does not upgrade Superuser.
The Superuser is verison 1.0.3.0 by Koushik Dutta.
I have installed a different Superuser from the Playstore which does work.
There doesn't appear to be a way to remove the Koushik Dutta Superuser.
That's been discussed in the thread for that ROM.
If you install SuperSU in cwm (see Blueness's post), it will remove other superuser apps.
You should be able to uninstall with Titanium or link2sd or any other root app manager.
