Root Support Bionic Stuck at "Dual-Core" Screen. Help!
Okay, so I've tried to fix this thing for a while now, but nothing I've tried has worked.
The closest I've gotten to fixing it is flashing it back to .902, but it always gets stuck around here w/ the phone still stuck at the same screen. (Screenshot attached)
This all happened after I dropped it and the LCD cracked. I bought a new one, replaced it, and now it's stuck.
Please help. I don't know what else to do. Thanks in advance.
Update to rsdlite 5.7. Are you booting into fasboot before you try to flash 5.9.902? Are you using the cable that came with the bionic? If you are using a desktop are you using the USB ports on the back of the tower?
Does rsdlite recognize your phone? Does your pc recognize your phone? Are you using the factory moto cable?
Ran as administrator. Same result again.
How are you trying to get into fastboot. Are you holdng the both the volume buttons and the power button at the same time.
Yes.
It seems like it does, but everything shows as N/A. A screenshot of it is in the OP.
Don't think so.
No, just the stock cable. Is the factory cable necessary?
EDIT: Going to bed. I will get back to this thread tomorrow as soon as I get off work. Thanks to everyone that's helping me with this!
Yes.
Don't think so.
OK. If you need to pm one of us to help
Sorry, i am referring to the cable that came with your phone. Also, make sure to use the back usb ports on the pc.
