Lordvincent 90
CLICK HERE
This will use stl13(internal data partition) or create a file on sdcard to be used as swap.
And give you options to create different sized swap files and levels of 'swappiness' (rate at which files are transferred to the swapfile)
Just install terminal emulator
And use these commands
Sry I'm not kewl like kouma, no app, but this would not have happened this soon without his help. He showed me my mistakes, and helped me get the data portion working (ok, he got the data portion working, because I'm slow and have fat fingers and make typos) thanks kouma you tha man
To use the 'extswap' and 'bootswapfile' commands you must have /data on sdext as it mounts stl13 (the internal data partition) for this purpose
ERRORS ARE NORMAL
THE FILES REFERENCE BOTH sdcard and data partition...
If you choose extswap, you will see errors regarding sdcard
If you chose swapfile, you will get errors regarding /data-ext
BUT AS ALWAYS MAKE A BACKUP FIRSTInstructions
DOWNLOAD AND INSTALL ZIP AT TOP OF THIS POST VIA CWM FIRST
Open terminal emulator
First switch user:
SU
then create a swap file on your sdcard or 'data-ext' partition:
swapfileXX (size 12,24,36,64,96,128 on sdcard fat partition)
extswapXX (size 12,24,36,64,96,128 on data ext partition)
Then set swappiness:
swpXX (XX is swappiness in increments of 10 up to 90) errors in script are normal
Other commands
swapfile-off (stop swap file in use) errors in script are normal,
clearswapfile (stops swap file and removes all swap files created) errors in script are normal
Swapfile at boot WILL ONLY WORK FOR SWAPFILE ON DATA-EXT,
bootswapfileXX (XX is swappiness in increments of 10 up to 90) errors in script are journal
bootswapfile-off - removes bootswap
ERRORS ARE NORMAL
