Root Swap what size
40nintendo
Member
hi i was partitioning my sd and i set the sswap for 64mb but what is the best swap size for a hero
4gb memory card
ps. how many times can i partition an sd card
pss. im useing villian 13
Zero. You dont need one.
You can repartition as many times as you like if youve got the time and sanity to spare. Well, when i say as many times as you like, the limit is based on expected write cycles for the card, so probably at least 10,000 times. So, you know, go for it, those long winter evenings will just fly by.
Does compache have any benefits any more? I occasionally hear of people using it, even though rom devs seem to discourage it's use.
