Help swedish spring/wifi problem?
funkylogik
share the love peeps ;)
is there a known problem with SS rls5?
just noticed when i try connecting to wifi, it searches for a while+then says "unable to scan for wifi"
i dont use wifi much but im at my mums 2nite+can only get 2g mobile signal here :-(
i have blade wifi fix installed btw
try this:
using a root file explorer
reame the
/data/misc/wifi/ wpa_supplicant.conf
to
/data/misc/wifi/ wpa_supplicant.bak
reboot
it will respawn on reboot
you could delete also.... but better be safe...!!
