F fogle7 Member Sep 9, 2012 #1 xthedakmanx said: You can easily reenable it. Just extract the file attached, and put it in system/etc/init.d/, then reboot! It should work then! Click to expand... I do that and nothing happens, the permissions is set to -rw whats wrong?
D deathsled Well-Known Member Sep 14, 2012 #2 After I place the file in the correct folder I reboot into recovery and wipe cache+dalvik. It works for me once the phone is rebooted.
