Partition your SD card. Partition the 16 when you get it. You'll then have around 150mb free of internal. Cm has a feature called Dark Tremors A2SD. Only way to use it is to be partitioned. It tricks the apps to thinking they are running on internal when they're running completely off the SD. Normally Widgets and such don't work when an app is on the SD but with dt's they all do since the app thinks its running on internal.
