Is anyone else testing the Swiftkey alpha?
It's a new keyboard that's in development. It's quite hard to use at first but now that I'm getting used to it I can say it looks VERY promising. The word prediction is brilliant, and a 1/3 of the time(according to them) it guesses the word correctly. If it doesn't it usually gets it within one or two letters of the next word.
In terms of the ui it's not amazing at the moment, but being only the second alpha release I'm not too bothered, and hopefully they will make the keys a little bigger and make it look nicer overall, a bit like in the image on their website.
They aim to have their keyboards used on android phones by default and I can see that happening the way they're going at the moment
I recommend people sign up to the alpha - SwiftKey - Revolutionary text prediction for smartphones
edit- on second thoughts this should probably be moved to applications, seeing as it's not Hero specific, I'm just used to posting in this forum
reinstalling it makes it better for a while, but then it gradually gets slow again
