Root switch carriers?? (rooting question)
If i root my phone and my contract is up can i change carriers and keep the same phone? I want to do this with a "4g LTE" or get the "one x+".
To do that legally, you'll need a donor phone that you'll pull all of the identifying numbers (ESN, MEID) from, as well as its stickers from and apply to your new phone.
You'll then have to retire the donor phone - not sell it or use it.
And then, you will likely not get all services and functions to work.
yep what early said. but i would like to add that you will need to use cdma workshop. now the thing is there are many "cracked" version running on the net. BE CAREFUL. since they are free, they have been known to carry viruses. however, you can buy cdma workshop but it is not free and not cheap either.
i'm not too familiar with the process unfortunately so i can't help you out with actually doing it.
