Help Switch keyboards in lock screen? (HELP!)
I was fooling with the morse keyboard (Google's April's Fool app this year) on Droid Incredible 2, and sure-enough locked the phone. Now the tap keyboard is my only choice in lock screen, and it is all uppercase, unlike my password. There isn't an enter button, either.
Now that you've finished laughing, is there any way to switch the keyboard in lockscreen? The settings button comes up empty. If there isn't, is there anything I can do to unlock the phone?
Hopefully someone will be able to lend assistance to you over @ your device's support forum.
Hello and welcome aboard - thanks for joining the community. :)
Thread moved.
You should be able to bypass the lock screen with your email account.
Then I would uninstall that keyboard. (sorry, I don't know exactly what you're talking about with the tap keyboard)
Hope that helps.
Far be it from me to suggest anything before a Factory Reset :p
...but I swear I broke into my wife's phone once (for her, really!) bypassing the lock pattern with her google account info. I can only assume that option is available with the "password" lock instead of the "pattern". Once you're in you should be able to uninstall that app and be home free!
Otherwise bberry is right. Factory reset boogie.
