Help Switch Pro broke my Data Connection
zeroeight
At least, that's how it seems. I bought it, DL'd it, installed it, and then set the Data Connection widget on one of my screens. I tried to use it, but nothing happened. I then turned Data Connection on by holding down the power button, and then the widget started to work. Then it stopped again... So I switched the settings to APN in Switch Pro, and tried again. Not only did nothing happen, but when I tried to do it via the power button again, it didn't work.
When I say nothing happened, the widget did actually change, suggesting it had worked, but the icon didn't appear in my notification bar, and I couldn't connect to the internet.
I've since uninstalled Switch Pro, but still my Data Connection isn't working. How can I fix it?
Nevermind, it's solved now. Managed to find the info I needed (indirectly) in another thread, and then worked out how to set my APN back to default (because SwitchPro had changed it and wouldn't change it back via the widget).
All good.
Yeah some of these switches change or append the APN at given times, to prevent connection. It then changes it back at the times you specify.
