The_Superhoo
I want to switch to stock ROM to get GB, but I cant plug my phone into the computer.
The mini USB port is all jacked up, and the only way I can charge it is using a battery charging dock, and then putting the charged battery into my phone.
I feel like I read in the past that you could make your phone accept an OTA while rooted, but mine wont find the update
Any help? Thanks
Any help? Thanks
I really don't think VZW looks at hboot or recovery. You may wish to install the stock recovery after you have flashed the OTA rom not that I think VZW will check but if someone gets your phone after it has been "refurbished" and there is an OTA they can actually get it
