Switcher Widget
R3vel
Member
When I had my i5700, the only good thing about it was it had something called switcher. If I remember right, it had wifi, bluetooth, airplane, and GPS switches so you could easily turn them on/off. The switchers I have seen switch between last used apps. Is it available on the desire?
Yes there are a variety of switches available.
If you are Using Sense then if I remember you long press on the homescreen, select widget, go to settings and you'll get a variety of switches to use. Either that or use the Power Control Widget.
Alternatively there are more on the market from Beautiful Widgets, Curvefish and others.
I use Curvefish(I think) as shown here:
http://www.candecavies.co.uk/images/phone/redmain+1.png
