go to settings/applications/manage applications...
Sort and scroll down to whichever launcher you are using and deselect the defaults option. Then hit the home button and it will prompt you to select and if you want to, select one as a default. There is an app called home switcher, or something like that and it will allow you to switch "homes" without going into the settings menu.
