Root switching ROMs?
brandonmg99
I made a nandroid back up right after I rooted my phone. Also made one of my current set up. I want to try out either apeX or rubiX 1.0 so can I just flash my "root only " backup and if I don't like it just flash back to my current set ups back up?
How it SHOULD work:
Go into Clockwork, backup and restore, back up, let it go.
AFTER THAT
Put ApeX/rubiX on your SD card
Go into Clockwork
mounts and storage
format data
format cache
up on menu
install zip from sd
select zip from sd
navigate to apex/rubix
install
Then if you decide you dislike it:
go into Clockwork
backup and restore
restore
select backup
restore
In theory it should work perfectly like that. I had that work for me before I started getting md5 mismatch errors.
thats what i was thinking of. i just didnt know if it was that easy or if i needed to sbf. id rather just take the nandroid route if itll work.
Nandroid backs up three separate things: system, which is settings and pre-installed apps, data, which is downloaded apps and info, and cache.
You can restore them separately or as a whole thing and get back EXACTLY how you were.
I have apex on my SD, rom mgr never seems to work right for me, so if I go through clockwork I don't need to mount the system?
