droidkevlar
Android Expert
Damn Swype for closing the beta. Here is a link for the lite version that still works.
http://androidforums.com/htc-droid-eris/40128-swype-avail-eris-14.html#post743100
1. Transfer to your Eris via USB
2. Settings -> Application settings -> Check Unknown sources
3. Use a file manager program such as Astro File Manager and go to the location you stored the .apk
4. Install
5. After install go to Settings -> Locale & Text -> Check Swype
6. Open any email/text client and hold down the text box and you will get a popup asking what you want for input. Select Swype. You only have to do this once and it will do it for all your programs.
http://androidforums.com/htc-droid-eris/40128-swype-avail-eris-13.html#post607430
4. Install
