yes you can see it, edit it, etc.
Settings / Keyboard / User dictionary
I don't think it shows when you enter words through normal typing, but it does let you add words there which will work when you use swype.
Is there any way to view my swype custom directory and see all of the words that I've manually added?
)Huh?! That's the stock keyboard user dictionary and not the sywpe user dictionary.
Are you saying you are definitely seeing custom words that you've added with swype in there?
I'm pretty sure that's only for the stock keyboard.
So anyone else know where to find/view the swype custom dictionary?
Sorry if I wasn't clear - manually adding words to this dictionary WILL show up when using swype. But words you add when typing via the keyboard will not show up in this dictionary.
I did contribute and I did have something to add. I assumed you wanted to see the dictionary so that you could remove a word. I didn't realize you just wanted to browse it live to amuse yourself or otherwise. You don't need to be curt with me like that when I'm just trying to help you out.We know that, please read the thread again and then contribute if you have something to add.
I've been trying to do this for weeks. A few days of drunken swyping and you add a bunch of wrongly spelt words. NOw when i type and i see a wrong word in the swype suggestion box, i just choose that word and delete it then, then continue on wiht my typing. Not the most effecient method though.
!!To delete a word from the Swype custom dictionary:
- Enter the word you want that brings up the bothersome word(s)
- Select the word you want to delete. If it's in the edit window with other words, double tap it.
- Tap the Swype key
- Tap OK when asked if you want to delete the word.
Works like a charm for me. Good luck y'all!!
