MariposaNegra17
I had swype before the update and I kind of miss it...is there a new version that works with froyo?
Thank you! =)
Thank you! =)
Thank you! =)
Sign in from there beta page with your email you used to get it the first time. I just downloaded it from there. Open page from cell.
The beta is closed =(
That will be your only option at this point. We do not condone the illegal distribution of apks on this forum.The beta is closed =(
Me too.I just found the newest version and installed the apk and it seemed to work.
After upgrading to 2.2, you need to uninstall Swype, and then run the Swype Installer which should already be on your phone (if you signed up through the beta). It'll then re-download and re-install swype.
Has anyone else had the problem where Swype works for a while, but after a reboot, the keyboard border just flashes and you can't Swype?
I never had this issue before 2.2, and now it seems to happen somewhat regularly. It doesn't seem to happen after every reboot, and I can't figure out the pattern. I am part of the beta, and have reinstalled properly a number of times. I was just wondering if this is a known or common bug before I reach out to them.
It's not swype. You need to do a factory reset on your phone. Then install your apps.
No, Swype is the issue. I was just looking over their forums and they are aware of the issue and it has been pushed to the development team. A lot of people have recommended a factory reset, but by no means is that a required step.
Hmmm, that's odd that it isnt working for you. I'm using it to type this, and have been since my update. I did do a factory reset, and as far as MY phone goes, I think that's why most issues have not happened on mine. I haven't had to hide it or restart it, and would def be annoyed if I had to do so.
I just realized this last night. I refuse to uninstall/reinstall swype every time I reboot my phone, that's just ludicrous. Swype needs to fix the program.
That's odd. I'm updated to 2.2 and have reset my phone 2x. My swype works the same as it did before the update.
I hope this doesn't change because I can't go back to chicken pecking.
I uninstalled it through the Market and now when I go to "Manage Applications", I do not see the Swype Installer anywhere! Am I missing something here? Thanks.
I posted my system logs to the Swype forums and they have identified the issue (as eipee posted). What is happening is that Swype is starting before the app cache is fully mounted so the license file doesn't get loaded. For those of you who aren't having the problem, it may be because the app cache mounting fast enough to get the license file. In my case, I have to toggle the input method to touch, then back to swype after every reboot.
Factory reset/data wipe hasn't helped in my case.
