Help Swype help PLEASEEEEE
scooz16
so I DL'ed swype last night. It worked perfect.
I restarted my phone this morning and now it's not working?? I can see the swype line but the text isn't going in. If I tap each letter it works. help please!!!???
This is a known issue with Swype on the Inc. I dunno if they're able to fix it or not. The work around is to long press on the text box and select Input method. Then select Touch Input. After that repeat the process and switch back to swype. PITA but it works.
