If I go into Memo - Create Memo and type in "s" and then tap the space bar, it changes the "s" to an "a". If I type in "5th" and hit the space bar, it changes it to "4th". If I use the keyboard, it does not do this.
That's because the update cleared the Swype dictionary and made some changes. After you enter "s" you need to tap the "s" that appears just to the left above your Swype keyboard. It'll then ask you if you want to add "s" to your dictionary. You can tap the new message to add it or just continue typing.
