Help Swype languages disappeared after upgrade
Kenbeek
Hey,
I recently upgraded my X5 to a 2.3.5 installment. So far it's been great (battery lasts like 4 times longer) but with one issue: I can no longer use Swype in some of the languages I could before. My choices are now limited to UK/US english, French, German, Italian, Portugese, Spanish and Russian. In particular, I'm interested in getting it to work in Dutch (Nederlands) again.
Does anyone know how to fix this? Swype came pre-installed on my phone, and I'm currently using swype version 3.26.92.36220.36227.6191.U8800
Much appreciated,
Thomas
Could u please tell me that how did u update ur android? im trying to update bt i cant. i got android 2.2.1 .
Thank u so much
ROY
Thank u so much
ROY
A colleague of mine brought an SD-card with the update file to work. I'm not sure how to acquire this file, I guess you could ask around on this forum.
You then turn off the phone, insert the SD card, press the volume up and -down button simultaniously, press the power button, whilst holding the volume buttons, until a screen saying 'update in progress' (or something along those lines) appears. Wait ~10 minutes and you're done. Make sure your battery is fully loaded before starting the upgrade. If your battery dies mid-update you'll be stuck with nothing more than a weird-shaped brick. Also make sure to sync your important data (contacts, pictures) beforehand. They too will be gone after the upgrade.
HUAWEI U8800 IDEOS X5 Software Upgrade from Android 2.2.1 Froyo to 2.3.5 Gingerbread. Below are the steps I performed. Please read carefully, and kindly understand and remember that there is always the risk of irreparably damaging the phone. Good luck.
1. Using a PC go to www.huaweidevice.com, (as of Thursday, January 5, 2012) select Support > Downloads > By Category = Mobile Phone, Product Type = Smart Phones, Product Name = HUAWEI U8800 (not HUAWEI IDEOS X5) and download software [Name: U8800 V100R001C00B522G001(Normal)(Gingerbread), Date: 2011-12-28, Size 192.15MB].
2. Extract ZIP file to PC. It contains only 2 items ("U8800 Software Upgrade Guideline.pdf" & "UPDATE.APP"). Please review the PDF thoroughly (2.2.2 is mentioned instead of 2.2.1 which can be misleading/confusing).
3. Information BEFORE upgrade: Settings > About phone > Model number = u8800, Android version = 2.2.1, Build number = U8800V100R001C00B136SP02. My X5 is less than a week old with no modifications such as rooting, custom ROMs, or MicroSD repartitioning.
4. Ensure phone's battery level is sufficient (mine was at 71%). Back up data (for example, export contacts as VCF to the MicroSD card). There's no need to perform "Factory data reset" (to erase data on the phone) since the upgrade process does this.
5. Connect phone to PC using USB cable and "Turn on USB storage". Copy the "dload" folder (containing "UPDATE.APP") from PC to the topmost path (or root directory) of the MicroSD. Make sure to "Safely remove USB Mass Storage Device" from PC, then "Turn off USB storage" and unplug USB cable. Verify using File Manager (path should be "\mnt\sdcard\dload").
6. Shut down phone (Press and hold power key, and select "Power off" from "Phone options").
7. Press and hold Volume Up + Volume Down + Power keys to turn on phone (I suggest pressing and holding the volume keys first before pressing and holding the power key). Release all 3 keys when HUAWEI logo & name appears. Phone is now in upgrade mode, and update runs automatically. Battery status indicator LED will slowly flash red during update, and screen will display the following:
- Firmware update, Step 1/2, Unpacking, [Progress Bar], The full update will take approximately 2 minutes. Do not turn off the device.
- Firmware update, Step 2/2, Installing, [Progress Bar], Do not turn off the device.
- Successful completion (Kindly excuse me as I wasn't quick enough to take note of the exact final screen).
8. Once update completes successfully, phone will shutdown automatically. Please note that phone is supposed to restart by itself according to the final screen. In my case, it didn't power on by itself, but it may be different for others. If nothing happens, wait a little longer then manually power on phone. A fancier Huawei startup sequence shows, update resumes and performs some quick internal formatting.
9. Information AFTER upgrade: Settings > About phone > Android version = 2.3.5, Build number = U8800V100R001C00B522G001. Reconfigure your personal settings and welcome to Gingerbread.
Observations/FYI only:
- Video playback has indeed improved just as stated in the PDF file.
- As expected, there are additional OS configuration options available, however, there is still no way disable screen locking and all vibrations out-of-the-box.
- Lastly, only the power key can wake up the screen after timeout, whereas prior to the upgrade you may also use volume up and down keys to wake up the screen. Though this seems insignificant, I find the volume keys conveniently accessible and easier to press compared to the power key, and I would have preferred not to overuse the power key. Oh, well...
did you resolve the swype problem? I have the same issue (Nederlands). I tried to install the beta from swype but that's not possible when you have a pre-installed swype available.
Uninstall Swype is not possible, unless the phone is rooted (which, for now, i do not want to do).
Any suggestions?
Hi Kenbeek, Touch Menu > Settings > Language & Keyboard > Select Language and select phone language. I presume you require Dutch language on the phone? Neil.
