Help Swype post 2.2 install
Xoji
This is more of a preemptive post for anyone that comes into the same issue as I did. My Swype was not working, so I had to uninstall, run the installer again, put in my Swype beta information to login, downloaded the app again and it worked fine afterwards. Just don't panic if it happens to you too. :)
I had the same issue, and every few days it stops working again, but I figured out I don't have to keep reinstalling it. You just have to change the input method to something else and then back to swype then it should work again.
