Anybody else experiencing a weird bug where SWYPE stops working when the battery is very low (somewhere below 20%)? I had my battery die a couple times and also reach very low charge and SWYPE will stop working. Regular input is fine. I go into the settings and make sure it's enabled, but when i run the tutorial, it doesn't prompt for which input nor does the tutorial run after the first example.
Where else can I change the keyboard input? The layout is the SWYPE keyboard layout and it will show the swyping motion - however it won't print out any text.
I'm usually pretty good about keeping my battery from draining, but I don't always have that luxury.
