Root Swype problems
dberthia
Member
I rooted my Bionic, removed the stock version of Swype using TBU, and installed the latest beta version. This all works great until I reboot the phone, then I get constant Swype force closes. If I uninstall and reinstall Swype, it works fine again until I reboot, then I see the problems again.
Any suggestions as to how I can break out of this cycle and have Swype work properly after a reboot?
Search the Motorola Droid Bionic thread (parent to this one) for 'ATTN: Swype Lovers' by Messenger13, last post on Sept 13. There are detailed instructions.
Thanks for that link. Starting there, I eventually found the solution on Swype's forum. For posterity, here it is:
If you used Titanium Backup like myself to "uninstall" pre-loaded Swype, then this may be the answer to your problem.
It will require you to have a Root Explorer-esque app.
First, uninstall all traces of Beta Swype Installer, and the Swype it tried to install. Then, open your root explorer and change to R/W so you can change some extensions.
Rename: \data\dalvik-cache\system@app@Swype.apk@classes.dex to have a .bak at the end.
Rename: \system\lib\libSwypeCore.so to have a .bak at the end.
Redownload your Beta Swype installer and go forward with the installation of Swype. It worked like a charm for me!
There were those two files left-over that Titanium Backup did not remove for me. If you used the same method to uninstall, then perhaps this will help!
I am so lost. The problem is i read that original post and it did not work the first time so i think i messed up. What version is the beta version of swype i get confused on tibu now. I promise i am not an idiot i just got exited about better swype and kind of rushed it.
Edit: I figured it out. I just retraced my steps and it works. I love the new version already.
