Help Swype question
bradm23
Member
Just got swype the other day and loving it. The only thing I don't know what to do is have it auto space after a period. Having to hit space is very annoying
When you hit the period, swype to the spacebar right afterwards. This works with all punctuation so you don't have to hit the symbol key. You just slide from the key to the spacebar and it will input whatever the alt key is for that option.
Xda fourms has a post with a droid does and htc theme. You cab download the file right from your phone and install it. I went with the droid does and its incredible.
If you have auto space turned on, then all you have to do is lift your finger off of the screen when you finish typing a word and when you begin to type the next word it will auto space for you. If you want to add a period or question mark(thats all the punctuation I use for texts)then drag your finger from period or question mark to the space bar and it will enter the symbol, auto space and capitalize the next letter. Nifty.
Every time i swype the word "want" swype ALWAYS types "wasn't" ive tried hitting the S key to change it, ive tried jumping the s like the tutorial shows, but still cant get it, its anoying because its usually really accurate. I wont read my text after i type it, then i read it later and it says something like "hey wasn't to go out to dinner?" yea.... help
