Help Symbols, backspacing, auto-correction? STOP!
ScubaCA
Member
How do I stop some of the symbols from automatically backspacing one space when I am typing?
For example when I type, "I'll be there @ 3:30" it auto corrects to, "I'll be there@ 3:30."
It does this with the @, &, ", - , and I am sure others. I end up having to delete the symbol, add the space again, then type the symbol.
HOW CAN I STOP THIS FROM BACKSPACING ON ITS OWN!
ScubaCA:
This was on of my biggest peeves of the Droid X Keyboard. I could never figure out a way to keep this from occurring.
Finally a friend of mine who also has the Droid X, turned me onto another alternative keyboard: Smart Keyboard Pro.
It is $2.73 dollars and it has been the best money I have spent as the program gives you 7 different keyboard layouts ( I personally have found the Android and HTC Layouts to be the most user friendly.)
You can get it from the Android Market or over at Appbrain: Be sure to download the English for Smart Keyboard Pro pack: Links at Appbrain are:
Smart Keyboard Pro: Smart Keyboard PRO - Android app on AppBrain
English for Smart Keyboard Pro: English for Smart Keyboard - Android app on AppBrain
As you type in words that are normally auto-corrected, you can select them to save them into the dictionary and when you use those words again no more auto-correct.
Under the Text Prediction settings, there are no fewer than 18 different settings that you can tweak to your liking.
Hope this helps out...
I am out....!
Is there anyway to modify the physical keyboard the same way to stop this annoying occurance? I text a lot and it's very frustrating. I have to wait until 05/2012 to get the Droid X as my AT&T sucky commitment ends then.
Thanks for your help!
