Help Sync and Disk drive
Hi
Had my XE for about a week now and for no reason at all my pc wont recognise the phone. Tried rebooting both, also reinstalling HTC sync. Removing mini sd card and restarting. Tried 2 different phone leads, one from existing HTC desire, new one supplied with phone. Both recognize that the phone is plugged in because its charging the phone.
When I first got the phone and plugged it in to lappy i got a drop down bar on phone, now I get nothing, so i go to connect to media and change it to disk drive and still nothing happens. I then try and run HTC sync and it says no phone connected.....Im at a loss as to what has happened in 2 days.......
Any help will be much appreciated
Mark
more info
Just plugged my old desire in and worked all ok....disk drive and HTC sync......so that rules out cables and usb and lappy.......AAAARRRRGGGGHHHH
I had a similar problem tonight. I was convinced it was the phone and tried to change loads of settings on the phone. I then realised it must be my cable. I was using a different cable and not the one that came with my phone. I switched cables and sure enough, when I opened the notifications bar, the menu was there for me to use the phone as a disk drive.
Even the other cable had charging symbol on. To me the cables look the same but there must be some difference. :)
I see you've already tried the cable that came with the phone. Not sure what else could be wrong. :(
something else I've noticed tonight.when I take the lead our of either the phone or lappy the icon stays on the top right hand side of my phone.....takes me a while to get rid of it.....only thing I can think of is a format....but I will loose a lot of stuff
