Help Sync contacts from iphone?
Ok, im at work and have no computer to use outlook.. i've tried to download google sync for iphone but i don't think it exists. I would really like to stop carrying around this iphone and i don't want to enter each of my contacts manually. Any suggestions?
If you have a Mac you can export out your contacts to a Vcard. Import them in to Google contacts.
Not sure the Windows options but I am sure it would be near the same.
I just went into Itunes and there is an option to sync contacts and I just chose Gmail. Once they synced over they copied to my X just fine. Good luck.
I just tried the google sync method and was unsuccessful. I don't know if i made a mistake somehow, but i guess i'll just try the urines thing when i get home.
