Sync files without wires...
Giving "Drop Box" a try now... sounds a bit more advanced than the "Awsome Drop" App as it's more like cloud-based storage, which sounds great!
I'll let you know how I get on!
:D
Ok.. so the main differences are:
Drop Box: Online Storage and Sharing of Files, which has the option for download for offline use.
Awesome Drop: Sync's files direct to your phone for immediate offline use.
I now have BOTH!!!
Two great Apps! Thanks Guys! :D
If you're comfortable using FTP, it's handy as hell. I use SwiFTP to turn my phone into an FTP server, then connect using Filezilla on my PC. So much handier than sticking the cable in, and the cable is like, a foot away.
I use a Whindows Home Server fro HP. Does anyone have any useful tips on apps to use to access files on that through the network just as I access it from our computers?
along the same lines, I use TunSync for keeping my iTunes playlists & tracks sync'd with my phone wirelessly.
(My aim is to ditch iTunes altogether in favour of Winamp, but it's a gradual process!)
