I tried entering the info there and it's either host unknown or server not found. It's just odd because I entered the same info into a supervisor's DX and it went just fine.I just used the built in Corporate Sync. It sync'd my Outlook Exchange e-mail and calendar, no issues.
Go to Launcher -> My Accounts -> Add Account -> Corporate Sync.
There isn't a space to enter the exchange server on that menu, but if I remember correctly it just gave me an error and then I was able to input the rest of the information (or I just kept digging until I found where to input it). In any case, I didn't have to install anything the phone didn't already have.
Ok, try this...I tried entering the info there and it's either host unknown or server not found. It's just odd because I entered the same info into a supervisor's DX and it went just fine.
That's what I've been doing :/ I can't stand Novell...Ok, try this...
Go to Launcher -> My Accounts -> Add Account -> Corporate Sync -> Menu button -> Set up manually.
That's where I was able to enter the Exchange Server details.
Hope this helps.
