Help Sync problems - Just calendar though!
hi - the sync software wont allow me to sync outlook calendar. the option is just shaded out and i cant click on or off. it worked at first while work admin ppl gave me admin rights to install program, but now it does not work. not sure if this is linked to having admin rights? i can sync other thigns like files music etc thanks
got sync softwae to work except it cant find itunes on the computer
when I open the software on the computer it can find files for photos etc but in the music option if I select to sync with iphone it doesn't list any songs or playlists.
anyone else had similar issues - any ideas
(am running Vista)
Thanks
Using newest sync. Calendar and Contacts are greyed-out. Other categories sync. Status bar (top) shows triangle with exclamation mark, not the arrow circle as it should. Wildfire uses USB debugging as per the manual.
The problem affects all contacts/entries I imported via BR form old N95. Now this is a bit annoying. I cannot sync neither with system apps nor google services.
Wonder if anyone had a similar problem?!
