lseymour28
Just traded in my blackberry for incredible 2 and trying to find app that will sync to outlook on my pc...would appreciate any suggestions or info! Thanks
My email is road runner pop3. it is synced for my emails, but i also want my contacts, notes, tasks to sync as well. i saw an app called dejaoffice from companionlink software, but am so new at this and am not sure which app companies to trust. thank you so much for your help!!! Linda
Not so.Outlook is an email client, not a email address itself. Outlook is synced with an email address...
If you're looking for your Outlook contacts and calendar and such, HTC Sync supports this. Application - HTC Sync for all HTC Android Phones & HTC Smart
ETA: I don't use the software though, since I get all my contacts via my connection to my Exchange server and Gmail.
How do you sync outlook to soocial.com?
As for CompanionLink and DejaOffice - these will definitely sync contacts, notes, and tasks.
So check out SyncDroid and give DejaOffice a try. And be sure to let me know if you have any questions about our apps!
- David Z.
David,
With the CompanionLink and DejaOffice option, will Outlook sync with the default Contacts application that comes with the Droid or will we have to use the Contacts app within DejaOffice?
-Vickie
Ok. great. we'll give it a try and let you know how it goes.Vickie,
In short: Both.
CompanionLink syncs Outlook to DejaOffice. You can then use the contacts app inside DejaOffice. If you'd like to bring the data into the native Contacts application that comes on your phone, we've built in a setting into DejaOffice to allow you to sync DejaOffice to the native Contacts and Calendar apps. To find out how to do this, check out our help page here: DejaOffice Classroom - Android - Sync
- David Z.
