Help Syncing - appreciate any help
E10sp
Hello,
I have an htc desire hd and an iPad 2 that I would like to sync. It seems my calendar online syncs with my iPad and phone but when entering events onto the iPad calendar it doesn't show on the phone and vice versa.
Does anybody have any ideas as to why or what I need to do? I would really appreciate any help.
Many thanks
If you want to sync your calendar or email then then information should sync automatically if your using Google. So for example you can use the HTC sync software that can sync information from calendars, contacts or your email to Microsoft Outlook. You can then use the Itunes application to sync your iPad. You can setup itunes to use Outlook and this way you can have synchronization between the two different devices.
If you use Google for your email, contacts and calendar then it should sync all of these without any complicated configuration.
