Hello and welcome to Android Forums. Most calendars are designed to sync with your google calendar. If that's the case you just access your google account from your pc and set up your calendar and special events. They will then auto sync with your calendar app. If calengoo doesn't sync with your google calendar you will have to read through the instruction or ask the author of the app. You might also ask for help in this area here at AF if all else fails. Android Applications - Android Forums
