NajaSAKAii
Is there something I can do about my facebook, twitter, & myspace accounts not syncing all the time like I believe they normally should? Half the time the sync icon will be red (for not syncing) instead of green( which means it's syncing). When it is red there is a message at the bottom of the screen saying " Sync is currently experiencing problems. It will be back up shortly." It is a bit annoying because when I want my feeds and updates to update it won't. Is there a way to fix this?
