Alright, so I've been noticing the last day or two, I haven't gotten many texts or emails as it seemed. Well I looked at my sync settings and under google mail the sync time was about an hour behind. When I synced it again, it would refresh to the current time. I don't know why it would do this? I couldnt even find a setting that allows you to set the times between syncs. Anyways..onto the text messaging issue.
I've been using my wife's phone to text myself to try and figure out this issue..
Example: I send a text from my wifes phone to mine. Few minutes go by, nothing. I turn the screen on my phone, and bam there is the text. It's almost like I have to make the phone wake up? I have no idea. If I however, let the phone go and do not turn the screen on, I WILL eventually get the text, although it might take 8-12 minutes or so. Very strange. Between this, and the notification light only blinking for a few minutes, and only in one LED color, I'll tell you what. This guy is missing his OG droid bigtime, because that phone > this phone, lol. Any suggestions?
Thanks in advance.
*edit* I just set the sleep mode on my phone to *NEVER*, and it seemed to resolve the issue. Things sync as they should, HOWEVER this is the issue I had when I first got the phone, my phone would NEVER sleep. When I would look at the battery status the blue bar would be a solid line under the awake status. And now I'm sure it'll be the same because I told it to NEVER sleep. This greatly effects battery life, and makes it pretty bad. The funny thing is, this new syncing issue started like yesterday, and I've had my phones sleep mode set to automatic for like 2 weeks now, and stuff was syncing fine. Go figure.
Thanks in advance.
