Help Syncing the Inspire
meemoo752
Hi All,
I was wondering if anyone could tell me how Syncing the Inspire works with my laptop. I downloaded the Sync program onto my laptop and every time I connect it with the Inspire it does a sync. Great...now how do I find where things like photos are on my laptop? Does the Sync transfer/copy the pics it took on the phone to my laptop? If so, where are they? I cannot find them anywhere!!:confused:
Not sure if you're going to find much help with that, I don't think a lot of people use that sw. I sure don't know.
Easiest way to get pictures to your pc is when you plug in the usb cord, it will pop up a menu on the phone asking what usb mode, pick the disk drive or mass storage mode.
The phone will show up as a new drive in my computer just like a thumbdrive would, in that drive there will be a folder called dcim with the pictures inside. From there you can copy them wherever on your pc.
When I setup sync on my phone to my PC I get a screen to setup with folder to get and when I go to Gallery the photos are there in their sub-folders.
when i hook up my phone by usb cable, screen show no devices connected i downloaded HTC Sync an installed this on my laptop, still nothing i need help here, as to what the problem is.
If you go to [settings] > [Connect to PC] make sure the box that makes it ask you what to do when connected is checked. If not, it'll just do whatever the default action is ...usually just charge your phone.
Then, when you connect the phone, a popup window will have several options including "Mount as a Disk Drive".
