Root system apps
fullbloodedmut
i was wondering how would you go about taking a system app from one fone and install on another,for instance i have the connect and was trying to get the quick memo apk onto the esteem,or basicly anyother app,or is there anythinng else i could take from the connect and swape with or vice verses? thanks
Depends on the app
What app is it? I think most connect apps are compatible.
Put the app in system folder and restart
If it don't work, there may be a associates file needed to run the app, and you"ll have To do some searching.
For example:
To use ported ics keyboard, I do the same, but you must also take file "latinime.so" file and add it to system/lib/ and it fires right up.
Same went for a launcher I was using
If your program is called.... "doverapp". There may be a file called "sysdover20set.so" that needs to be added in order for it to work.
Make sense?
gotcha just need to llook further into the files of the sys app,quick memo is one of the apps,its prob going to be complicated because you have to use the volume buttons( rock them back n forth ) then it allows you to write on any screen and capture it and send it,just trying sumthing new
Didn't black plague rom come with quick memo?
not sure on that,ill hav check into it,was trying to copy connects files,n no need to get to stock unrootyed lol wat a morning,shoulnt of started so quickly,im in a bind cant figure unroot for connect,but ill gt it,i know the lg update tool would do it under phone recovery but the updfater is all ? marks now even for the esteem,its nt working right,have u checked it out lately?
