Help system auto update
Jayme
Does GB automatically update? and is there a way to turn of auto update? I would rather stick with FROYO for now.
thanks
Usually you are prompted or have to go in manually and check for updates before you will get it.. but some people have it pushed onto their phones I believe.
If you are rooted you could stop it by freezing some apps that the system checks for before the update.
