System (disk) Repair
gmermel
Is there an android app similar to the Mac disk Repair utility?
My tablet is experiencing a number of force quits and network delays.
When this type of stuff starts happening on my computer my first step is to Repair the disk and permissions
Yeah mate. I doubt that just tidying the storage is gona do anything tbh. Im not a hard drive based computer person at all but in android terms, ive never heard of that being a cure for the issues youre having.
Did you recently get a firmware update or install a new app just before the problems started?
Is the tab rooted? if not, you can try booting it into recovery mode and wipe the Cache Partition
I don't know what Mac disk repair utility is, but if you have a removeable SD card, you could plug it into a PC and run "Error Checking" on the SD card. I don't think that's likely to solve your problem but it's probably worth a try.
As Funkylogik said, I'd:
1) Uninstall any recently loaded apps to see if that fixes it.
2) Run a complete Titanium Backup back-up. Do a factory reset (or a cache wipe if you're rooted) and then a complete Titanium Backup restore.
