Root /system/ dump
joshua8790
Member
Kyocera RiSE System Dump
Warning: These are freshly copied off the phone. I have not tested pushing it back to the phone, and I no longer have the unit. Use this at your own risk.
If you know how to push files to your phone by ADB, you should be able to save your phone if you did something like flash Beats, remove an essential file, and so forth.
Download: Kyocera Rise /system/ dump
Enjoy. And if this helps, just give me a Thanks!
